SIT Connection Manager
Hi all,
I have installed the Simulation Interface Toolkit and I have read the SIT manual. However, when I want to do the example which appears, there is a problem. This is, in simulink there isn`t any problem but in Labview doesn`t appear the SIT Connection Manager on the front panel menu bar, Tools»SIT Connection Manager and I don´t know why.
If someone could help me, I would be grateful.
Thank you.
(4,780 Views)
Do you have multiple versions of LabVIEW installed on your computer?  If so, you may have installed SIT to another LabVIEW folder.  Go to your LabVIEW\project folder and see if sitwiz.llb is there.  If not, then SIT did not get installed to this version of LabVIEW.  Check other LabVIEW folders on your hard drive and see if it got installed there instead.  If so, then you can uninstall SIT, then reinstall and make sure the correct version of LabVIEW is selected when going through the installer wizard.
Good luck,
-D
(4,769 Views)
excuse my inconveniences but when I install the Simulation Interface Toolkit, where must it install the SIT in the hard drive directly as a folder or in C:Program Files\National Instruments\.........\Labview8.2?
Thank you for helping myself.
(4,743 Views)
Yes, when the installer runs, you must pick the folder where the LabVIEW is that you want to use SIT with.  For instance, if you want to use SIT with LabVIEW 7.1, and you installed LabVIEW 7.1 in the default location, then during the SIT installer, you would choose the following install location:
C:\Program Files\National Instruments\LabVIEW 7.1
Good luck,
-D
Message Edited by Darren on 10-18-2006 10:17 AM
(4,719 Views)
Thank you very much Darren for helping myself.
A greeting.
(4,704 Views)
