SIT 5.0 problem with dll
I wanna use my matlab dynamic model in labview. So, I used Simulation Interface toolkit (SIT 5.0) and also make dll with Matlab Real Time Workshop. My Model act well in Simulink Model. But when I built it to dll and import in labview, it doesn't work proper. It seems my dynamic doesn't respone to my control input. So I checked my input in dll model and track it when I run the labview program. My control input correctly recieved in dll model. I think I have got problem with two integrator block in my simulink model. I don't know what to do. I checked everey solver and every sampling. if anybody can helpme , please do it as soon as possible. I really get stock in it.
(2,479 Views)
can you post ur code or dll so that other users can have a look?
 I believe the problem might be with the data type assigned to the inputs and outputs of the DLL. Can you try the dll after removing the integrator block?
Vaibhav
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(2,446 Views)
