SHOW SUB VI
Hi all,
i have been working subvi concept,
The following file attached contains a main file, which calls the subvi..
Now the problem is while the subvi is running, i want that the subvi should be visible untilit ends.
can anyone help?
Regards
(3,262 Views)
In the main vi right click the sub vi and choose 'Sub vi Node Setup'
Greetings from Germany
Henrik
LV since v3.1
(3,256 Views)
i tried that also but it didnt worked.
regards
(3,253 Views)
can you post your vi in 8.5  version??
i think above mentioned solution should work....after right clicking the sub vi icon select show front panel when called option.
(3,240 Views)
You will need to open the subVI, navigate to File -> VI Properties, choose Windows Appearance and click on Customize. Wouldn't you want the subVI to close after the application ends? Your design is not going to let you do that. You should use queues or notifiers to communicate between the main VI and subVI.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,234 Views)
Hi shrekt,
Check out this for loop indicator nugget. It does what you are asking for.
For loop indicator nugget
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,227 Views)
