08-02-2005 01:14 PM
08-02-2005 02:04 PM
08-02-2005 02:30 PM
08-03-2005 06:13 PM
There is an example online that does exactly what you are looking to do in CVI (NI's C environment) and it might be a good guide for you to follow. Check it out.
Kind Regards,
08-04-2005 02:47 PM
08-05-2005 06:07 PM
I found an interesting website on the SHFILEOPSTRUCT that I thought I'd share. It isn't necessarily directly related to what you are doing, but it talks about a particular hang-up that could be related to the problem you're experiencing. Two of the members of the SHNAMEMAPPINGS struct are declared as LPSTRs, however, they are laid out as DWORDs. I wonder if maybe the same is applicable to the two LPSTRs that are suspicious in your case (pTo and pFrom). At the bottom of the page, the website illustrates the correct way to accomodate them.
Kind Regards,
