SERIAL communication using VISA, with micro controller....
i am doing serial communication through VISA. I am not getting synchronization between micro controller and LABVIEW.Actually this micro controller works as ADC & DAC in my process control system.ie. as a card.  i want a programme to wait the VI till any data come in the serial buffer. please anyone help me .other solutions for synchronization also accepted.
(2,805 Views)
Communication through VISA with micro controllers, is like any serial communication.
You should have no problems. Check your settings. Try asynchronous mode also.
(2,803 Views)
Hello Anoop P S,
One very important detail you need to look at is the voltage level needed for your micro-controller.  Micro-controllers usually work with UART TTL 0-5V level, whereas your computer works with RS-232 -12 to 12V voltage levels.  You will need a RS-232 Receiver/Transceiver to convert the voltage levels.
If you are already using a converter, I suggest trying to communicate through hyper terminal first, sending/receiving a single byte.  Also make sure you disable flow control on your COM port, make sure you are using the same baud rate/data bits/start bits/stop bits.
O. Proulx
www.ni.com/support
(2,768 Views)
