SEND TO FILE:Datalog
I am new to Labview and having some problems which i'm sure is very simple.I've looked at examples and other info but can't see
what i'm doing wrong.
I am trying to save voltage results and time stamp from a datalog experiment.
The voltage output is coming out of Eng Units and i have a date stamp string.I don't understand how to bring this data together so the save to file works.
At the moment tried Build array and Bundle and Cluster, but because they are differant types of data this does not work.
Can somebody help ?
On the same subject some of the functions ask for a delimiter with Tab being default.
What other delimiters are there and what do you type into the constant box ,a string like "comma" or  " ,"   ?
Regards
Labtech5555
(2,684 Views)
Hi labtech55
which format is your voltage? I don´t know Eng Unit. Can you format your voltage value to string?
Mike
(2,680 Views)
Hi Mike,
The output from ToEng Function is 32 bit Real ~6 digit precision.
Yes a string Version of this would be ok if this is possible ?
At the moment using Build Array and then Write to spreadsheet functions but Build array does not like the mixed
data of string from date stamp and the 32 bit real data from ToEng
Labtech5555
(2,676 Views)
hi
i attach a picture which shows how to convert your data into string.
Mike
(2,663 Views)
