SE project and log files
I'm new SE user. I need a new project but most settings are same as one exist project, so I use "save as" to create the new project than modify it. Problem is the all log files also show up. If I delete them,it will delete data file in SE data folder but the exist project need them. I can export project setting to XML file, but that is just for record, can not import setting. How to change the log files list in project file but not change the data file in SE data folder? Just like to disconnect them with new created project.
(2,513 Views)
Do you mean SignalExpress? If so, why are you posting to the LabVIEW board instead of there?
(2,509 Views)
sorry. didn't see SE board at that time. re-post there now. Thanks!
(2,498 Views)
