SDO write error
I am trying to use SDO write on a node, I am able to do that in vi attached below. But on the second one it gives me a "Sub-index does not exist" error, the rest of the code is working fine. Only difference between the vis is that the are in two different projects, the are run on the same target. Is there something I am doing wrong?
(2,338 Views)
Hi Neowise,
There is a lot of error handling missing in the 2nd VI (image)…
Does the device support that index/subindex?
(2,324 Views)
Yes the first vi (working.png) runs perfectly, so the index and subindex are supported on the node.
Anurag
(2,270 Views)
The issue is resolved. The object index had to be given in the decimal form ie (25088) instead of 6200.
(2,163 Views)
Hi neowise,
once you enable the radix display on your numeric constants you can also input hexadecimal values...
Recommendation: ALWAYS enable the radix display or the display mode indicator for strings when you want to use non-default display modes!
(2,153 Views)
