SDIO support with Labview RT
Can I use a custom SDIO board within Labview RT?
If the answer is yes - please explain also what i need to do...
(it can be done with Labview PDA...)
(2,644 Views)
Hello Co,
It could work but we cannot give you any guaranties. When you follow the link below you will get at a Knowledge Base that deals about this matter. It also contains some useful links to other Knowledge Bases and tutorials which you may be interested in:
http://digital.ni.com/public.nsf/allkb/E3485A8B93929DAC862572D6005240EF?OpenDocument
Hope this helps,
RikP - National Instruments Applications Engineering
Rik Prins, CLA, CLED
Software Development Engineer
(2,627 Views)
