SCXI problem with group limit of 16
My NI SCXI chassis has four SCXI-1124 modules in it, which supply me with a total of 24 analog output signals.
I currently have Labview configuring the outputs by providing the AO Config VI with the appropriate module/channel number. The AO Config VI then sends the information to the Hardware Config VI, where I specify whether the signal is a voltage or a current before sending it out. This interface is operating perfectly well.
However, because Labview views the SCXI chassis as a single device, I have to specify a group number for each output channel. Since the group number can only range between 0 and 15, I am limited to accessing only 16 channels at a time. Is there any way I can overcome this limitation and access all 24 of my channels?
K. Lee
(3,256 Views)
Hello Klee,
You do not have to have a group per channel. You can have many channel within the same group for your acquisition. Try just leaving that input unwired.
In addition, I would advise you to use DAQmx instead of traditional DAQ for your program. DAQmx is way easier to program.
(3,247 Views)
Serges,
Thank you for your reply. I tried leaving the group ID input unwired for all 24 signals, and as a result none of them worked at all. Is there anything else I can do?
I have passed on the recommendation for DAQmx, but I'm afraid that I am stuck with traditional DAQ for this particular application.
K. Lee
(3,231 Views)
Hello Klee,
Let me investigate this further and get back with you.
(3,218 Views)
The AO Config function is only valid for buffered (clocked) analog output operations which aren't supported by the SCXI-1124. The 1124 only supports static (single point) updates. Just use the AO Update Chanels.vi from the traditional palette and give it all 24 virtual channels.
(3,206 Views)
Serges,
Thank you very much for your help. The AO Update Channels VI works wonderfully... except that it seems to be applying a gain of 2 before the output. When Labview commands the value x, the NI interface outputs 2x. The strange thing is that when I command x using the "Test" function in the Measurement and Automation Software, the NI interface outputs x. Why is Labview applying a gain of 2 to my output? I can divide all of my signals by 2 before sending them out, but that's not solving the real problem. Any help would be appreciated.
Thank you,
K. Lee
(3,184 Views)
Hello K.
I will look into that and get back with you.
(3,166 Views)
