SCXI and Single ended model on PCI6036E
I have one SCXI chasis connected to the PCI6036E
card to measure weights. Can I use the left Analog Input channel of
the PCI6036E card as single ended input channel?
If so, how to configer them and what's the format
of addressing the different channels? For SCXI, we use
sc!md1!0 something like that, then waht is the format
of the other single ended channel of the PCI6036E card?
(2,694 Views)
chenchen,
In order to access the additional channels of your PCI-6036e you need a SCXI-1180. This will allow you to access all of your unused 6036e channels on the front of your SCXI chassis. Once you do this you will refer to the unused channels just as if you only had the DAQ board (i.e. 0, 1, 2, 3, etc.).
I recommend calling our internal sales department at 1-800-433-3488 if you would like to purchase the SCXI-1180.
Ames
Applications Engineering
(2,694 Views)
But looks like I can only use ch1 to ch7. ch8 to ch15
are not available. Any suggestion?
(2,694 Views)
