SCXI 1600 - Labview (32 bit) - NI-DAQMX
I am trying to use an older SCXI system with the 1600 usb interface.  I have a Windows 7 32 bit install and can control in 9.3mx as per the archived document
NI-DAQmx and NI-DAQ Driver Support: SCXI
I see the document was archived 2/4/2020.
Is this document  up to date or will the SCXI drivers work with newer NI-DAQmx versions.
If not, I guess that means SCXI can only be controlled by 9.3mx drivers in LabView 2010 down to 8.5 as per
NI-DAQmx and LabVIEW Compatibility
Has anyone had success with more recent LabView/Ni_DAQmx combinations?
An older LabView version would work for me as I just need to implement a simple data logger.
(3,229 Views)
I would consider 2/4/20 very up to date!
If it worked with newer versions that would show it since 9.3 is probably about 7-9 years old.  If it could handle a newer version of DAQmx, a document updated in 2020 would reflect that.
(3,210 Views)
I'm not entirely sure if the document was updated 2/4/20 or if that date is the archive date.    Since the title of the document is:
Archived: NI-DAQmx and NI-DAQ Driver Support: SCXI
Updated Feb 4, 2020
I guess I can't go wrong using 2010.
(3,181 Views)
I read that as the document being updated on 2/4/20.
Maybe the update involved saying the document was archived.
(3,177 Views)
