SCR Phase Angle control
Hi All,
I'm trying to produce a chopped sine wave to simulate an SCR controlling
mains voltage. The output
only needs to be a few volts with an positive offset.
I've thought of making a table of normalized values to represent the fixed
frequency sine wave(50Hz)
and to switch the output to a fixed level(offset) below a certain output
value. That way I can control
the trigger angle. Of course the trigger is reset when passing through the
offset value.
I'm I on the right track here or is there an easier way with a prebuilt VM?
TIA for you help
Nick
(3,696 Views)
Greetings Nick:
You should be able to get good results with your technique. (You're essentially doing a poor-man's
Direct Digital Sythesis, when reading a pre-constructed table like you are doing) Another way to do this is generate a sine wave, using one of the sine generator vi's and then run it through a series of comparators (use comparison primitive) each with a different threshold. Add the values of each comparator output, and voila, this is your stepped wave. In this manner, you are simulating a "flash" A/D convertor.
Another way to do this, is to run a square wave generator (say at 400Hz) and MULTIPLY this by a sine wave at 50 Hz. This will give you a Sine wave modulated square wave, (or vice versa, since mathematically, they are identical!)
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(3,696 Views)
Hi Eric,
thank you for the ideas, I've been trying to get a square wave to chop the
sine wave but
I haven't had enough experience with LV as yet to figure it out. I'm going
to try to implement
you last suggestion, I'll let you know how I fair.
Thanks again
Nick
(3,696 Views)
Try this lil' vi
Eric
Eric P. Nichols
P.O. Box 56235
(3,696 Views)
