SB-RIO 9631 Safety regarding question
Hi folks,
we have a SB-RIO 9631 target that we are going to use for controlling a Quanser Inverted Pendulum model we also have in the lab. My question is if would be safe for the target to connect directly one analog output of the SB-RIO to a amplifier module (also Quanser made, the UPM-1503 version) in order to amplify the control signal and then feed it to a DC motor.
I guess it will be, but since it is not a conventional wiring, I thought I could ask for your impressions. The goal is to control the DC motor and thus the position of the chart/pendulum over the rail. The motor has a frecuency limitation of 50 Hz for safety reasons too, so I am going to implement a low-pass filter in LV before the output of my application.
Best regards, Javi.
LabVIEW Enthusiast
(3,034 Views)
Hi, Javi-R,
there's no problem at all in connecting an external amplifier to a sbRIO AO. It would be safe for the target besides it is a common practice to modify the voltage supplied by the target.
Saludos!
Jesús.
(3,013 Views)
Hi Jesús,
Thanks for your answer!
In order to prevent a motor failure, I have to implement a 50Hz low pass filter which will prevent higher frecuencies going into the motor, and also
a +/- 5 Volt saturation. In the specifications document it says that you should take care and not to feed the motor with signals more than +/- 15 Volt
3 A peak, and 1 A continuous.
I think I have the voltage constraint covered by the saturation block, but anyone knows how to implement a current limiter?
LabVIEW Enthusiast
(3,010 Views)
Hi, Javi-R,
you can implement a current limiter for your motor just copying the examples you can find on the Internet. Here you are a couple of them:
http://www.vidisonic.com/2008/07/10/current-limiting-circuit/
http://www.radio-electronics.com/info/circuits/transistor_current_limiter/transistor_current_limiter...
Just read your motor specs and choose that one that fits best.
Saludos!
Jesús
(3,008 Views)
Oh sorry... I mean how to implement it in Labview. The amplifier already has direct connexion to the motor, so I see no way to put a circuit in between.
I attach an amplifier user manual in orders you guys see it.
LabVIEW Enthusiast
(3,005 Views)
I just realize that maybe I could implement the limiter in Multisim and the export it as a Labview Block....
LabVIEW Enthusiast
(3,001 Views)
Yes, you can try. I hope it works!
Smiley Happy
(2,999 Views)
