SARTORIUS DRIVER
HELLO ALL,
Does someone have know where wan I found sartorius driver balance for
labview ?. I didn't found in labview site or sartorius site.
I have different balance of this manufacturer (CP124S, ...) but I found only
mettler driver.
Thanks a lot.
Rémi MOREAU
(3,543 Views)
Reading the scales of sartorius ..
all of them I ever saw used '\1BP\r\n' to request a value and '\1BT\r\n' for tara.
Since the RS232 setting is configurable you need to check the setting in order to use the same for your VISA serial init and the scale.
(All strings are in '\'-Code display, termination charaters might vary according to the scale setting)
all other tasks like scanrate, timeout, filter.. are specific to your application.
Greetings from Germany
Henrik
LV since v3.1
(3,542 Views)
Message à Rémi MOREAU,
je cherche en vain à piloter des balances saortorius via la liaison serie rs232 avec labview.
pour l'instant, sans grand résultat.
Avez-vous réussi ?
si oui, pourriez-vous me conseiller.
Merci d'avance
bambi54
(3,526 Views)
