S8 Serial Cable
Would someone supply me with the PINout of the DB9 end of the 182845B cable when used as RS422 with a 8421 board specifically TxA, TxB, RxA, RxB
(3,968 Views)
If you go to NI-Serial Help and search for "pin", the pinout for 485/422 can be found. The NI-Serial help is located under Start»All Programs»National Instruments»NI-Serial»NI-Serial Help. Go to the search tab and search for "pin". Then click on DB-9 Connector page. The pinout for a 485 signal will be the same as 422.
Also, the Serial Quick Reference Guide shows this information. Below is a link.
Missy S.
Project Engineer
RoviSys
(3,961 Views)
What I didn't realize was that TxA is TxD- and TxB is TxD+ and TxA is TxD- and TxB is TxD+. Found this by experementation.
(3,943 Views)
