11-21-2013 10:55 AM
Anyone know if it's possible to install LV2011 and LV2013 run time engines on the same machine? I want to run some older exes alongside their newer counterparts.
Solved! Go to Solution.
11-21-2013 11:13 AM
Yes, you can install multiple versions of the run-time engine on the same computer. A compiled LabVIEW application will automatically run in the correct run-time for the version in which it was built (and will give you an error if that version is not installed).
11-21-2013 11:18 AM
Many thanks, Nathan!
11-21-2013
12:00 PM
- last edited on
09-02-2026
01:37 PM
by
Content Cleaner
For some additional general information about exactly which Runtime Engines can be installed with each other, take a look at the LabVIEW Run-Time Engine Compatibility Knowledgebase article. It has a bit of additional information explaining the compatibility with SP1 versions and 64-bit vs 32-bit.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
11-22-2013 04:43 AM
Thanks Jeff, appreciate the additional info.
