Runtime Executable - Access Violation when saving to Excel.
I have a Labview 2019 developed Executable which I tried to deploy on a target PC. The Specs are
Dev PC
Windows 10 Home
LabVIEW 2019
NI-DAQmx 2019
MS office 2016
Target PC
Windows 10
NI-DAQmx 2019
MS Office 2016 .
When I am trying to save a report which works fine on dev PC , it gives me an access violation error on target PC. This used to work before on the same Target PC built with the same dev PC. Nothing is updated on both PC. But this time this error starts to crop up.
Any help is much appreciated.
(1,906 Views)
Sounds like LabVIEW Crashes With Access Violation Error When Using Excel_Insert_Textbox.vi
https://tmesystems.net/
(1,886 Views)
You might also consider attaching the Crash Report (which I hope you also sent to NI), as it will possibly suggest where you might investigate further ...
Another thing to try is to create a "overly-simplified" version of your program.  If you think this involved saving to Excel, write a tiny LabVIEW program that writes a little something to Excel.  [You might try the "Revised Generate Excel Report Example" I posted here in 2014 -- simply start typing "Revised Generate Excel ..." in the Search Bar and it should pop up].  If that works, then it might not be Excel.  If that fails, then its probably not LabVIEW, probably is Office Whatever-You-Are-Running.
(1,881 Views)
Almost certainly a version difference between Office installation on the two PCs. The Save method is notorious for that as Microsoft keeps adding optional parameters to it in never versions.
Your claim that neither computer was changed in any way only would be sure if both your computers had neither any internet access nor were in any way maintained by a central IT department!
Rolf Kalbermatter  My Blog
(1,848 Views)
