Runtime Error C-Rio Deploy
I am getting the following error when I go to deploy to a C-Rio from Lab View Dev Suit 2012 with LV 2011 SP1. I am running Win Enterprise X64.
Has anyone seen this error or know what would need to be updated on my system to solve it. I saw some solutions out there about the .net framework but I’m unsure of if that will help.
See the attachment for a screen shot of the error
Alan
(3,192 Views)
Hi Alan,
I have several questions for you:
1) Are you able to build stand-alone executables? If so, would you be able to manually install your application to your cRIO instead of deploying it?
2) Has this error always come up while deploying? Has deployment ever worked in the past?
3) What new changes or what new software have you installed recently?
I look forward to your reply, thanks!
Aldo A
(3,182 Views)
Aldo
1) This is when trying to deploy code in the project folder to the C-Rio
2) This is my first time working with the C-Rio because I had a contracting frim develope the code and it only occurs on my computer not the contractors.
3) I have all new software Dev Suite 2012 running LV 2011 SP1
Alan
(3,176 Views)
Hi Alan,
I suggest you download and install the 32-bit version of .NET Framework 3.5 for LabVIEW 2011 (32-bit) if you don't have it already. After the installation, perform a mass-compile of all your code (https://www.ni.com/docs/en-US/bundle/labview/page/mass-compiling-vis.html), fix any errors (if any), and re-deploy. Let me know if you run into the same problem. Keep us posted on your progress. Thanks!
Aldo A
(3,168 Views)
