Running VIs from Python using ActiveX
I have a collection of VIs that I want to execute from Python, so I'm accessing LabVIEW through ActiveX. Generally everything works fine, but there's a thing that puzzles me. The outcome of the VIs seems to vary with how I set the input parameters and also if the VI is pre-opened (manually) or not (where not is desired).
One VI gives the expected result if run like this:
inputParams = ["param1"]
inputValues = [value1]
viReference.Call(inputParams, inputValues)
Another VI works fine like this:
viReference.SetControlValue("param2", value2)
viReference.Call()
And a third VI needs this odd setup to work as expected:
viReference.SetControlValue("param3", value3)
viReference.Call(["param3"], [value3])
I have probably made mistakes elsewhere in the code, but I wonder if there's a "rule-of-thumb" how to pass values to a VI? When to use SetControlValue and when to use Call with arguments?
Ola
(3,779 Views)
I'm not sure about all the examples you've listed, but one common mistake is to not have the front panel controls and indicators mapped to terminals of the VI. If you are going to pass the arguments to the Call, they must all be terminals of the VI. You can use SetControlValue, however, on any front panel control.
(3,760 Views)
Thought you might be interested in this post...
(3,707 Views)
