Running Sum with array functions only
i'm currently struggling to find an array function to generate a running sum array.
My current implementation is working so far. But with bigger arrays (>100000 elements) the throughput is not sufficient.
Running sum means:
Each array element is the sum of the previous elements + the value of the according Input-array-element.
INPUT Array:
[100, 10, 95, 95, 5,5,100]
OUTPUT Array:
[100,110,205,300,305,310,410]
Does anybody know an array/matrix function to speed up this operation?
If possible without any loops.
Message 1 of 17
(8,734 Views)
Hi Daniel,
adding up 100k array elements takes ~1ms on my PC:
Using HighResolutionRelativeSeconds it just reports ~400µs for this routine.
With 1M elements it reports ~4ms, so this scales linearly with number of elements…
How much do you want to speed this up?
Message 2 of 17
(8,708 Views)
As fast as possible. Smiley Wink
Down to a few us would be a big advantage.
But in my opinion this is only possible by using array functions.
So the question is:
   Exists an array or matrix function which is doing this operation?
Message 3 of 17
(8,655 Views)
Based on what evidence?
The autoindexing FOR loop is extremely efficient. What makes you think otherwise?
Message 4 of 17
(8,642 Views)
Using array functions instead of for/while loops was in the past in the most cases a good tool to speed up such operations.
This operation is implemented in the SW part of a high-throughput FPGA application.
Maybe using an auto-indexing FOR loop is the best and fastest solution.
But I want to be sure that I'm using the most efficient implementation.
Message 5 of 17
(8,623 Views)
Hi Daln,
ohh wait: we talk about LabVIEW on FPGA now? Why didn't you mention it in the first place?
- LV-FPGA can use arrays, BUT usually insists on fixed-length arrays…
- LV-FPGA needs a lot of space to handle big arrays, so you need some streamlining of smaller chunks anyway…
Message 6 of 17
(8,620 Views)
No no....
This function is implemented in the SOFTWARE PART of an FPGA application.
So the FPGA is generating the data. This data is streamed to the Host-vi which is running on a PC.
And this "Running sum" operation is implemented in one of the Sub-vis on the PC.
No FPGA solution needed!
Message 7 of 17
(8,615 Views)
Do the math!
To add 100000 elements in a microsecond, an single addition would have to take 10ps.
Even if the CPU could do an addition in a single clock cycle, you still would need a 100GHz processor. Not realistic!
Message 8 of 17
(8,614 Views)
From that point of view: You are correct.
Like stated above:
  I only wanted to be sure, that there is no faster way to do this operation in Labview.
  This is 100% fine for me if it is the fastest way.
Message 9 of 17
(8,610 Views)
For a running sum, especially on a large array you'll only need to keep the previous sum and add the new number, no need to recalculate the previous values that'll be constant.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 17
(8,593 Views)
