Running Stepper Motor From an Event Structure
Version: Labview 2012
I have an event structure within a state machine. I want to use the state to choose to either drive a stepper motor by defined parameters, "ok button" state or via the signal given from a potentiometer "pour input" state, there is also a time out state.
The time out and OK button states work correctly, the pour input state does not. I have attached a copy of my full code, although it may not be easy to follow and also images of the states.
I took the initial code from an example. In the example the pour input state was driven by a dial, i have changed this to be driven by the pour input value. I think that the reason the motor does not move is because the pour input state does not execute (using probe) but i can't work out how to make it execute. When using a dial i think that the use of the dial somehow executed the state. I may be wrong in my assumption that getting the state to execute is the problem.
Any help or advice on how to get this working would be appreciated.
(2,804 Views)
 Please explain the subtraction between new and old value, if it is a pot as you say...new value(2K)-old value(1K)= input 1K?
(2,797 Views)
Accepted by topic author Carlr
Pour Input is an indicator, it will not trigger a value change event. Instead of connecting the new value to the indicator connect it to a property node set to "value(signaling)", this will trigger the value change event.
Ben64
(2,750 Views)
Using the value signaling node and removing the subtraction from inside the event has got my code working , thankyou. The subtraction was legacy from the code i modified, it think the dial required this, but using an analoug input does not as due to the loop cycling at high frequency the value changes are negligable between each reading giving input values of ~0.
(2,728 Views)
