Running Labview on WinCE 5.0 x86?
I have a WinCE device with an x86 processor.  It is programmable via Vis. Studio 2005.  I'd like to determine if I will be able to run a labview program on it, but I'm having trouble figuring this out from the documentation on your website.  Exactly what software do I need?  I have evaluation labview 8.0 software, but it looks like LabView PDA isn't available for evaluation (do I need to purchase this)?
Where I'm at now: I start an empty project go to New->Targets and Devices and can't do anything, my WinCE device isn't listed (but all I have is evaluation software).
(3,116 Views)
LV PDA itself, as far as I know, does not build your application, but delegates the job to eVC, so you should probably be OK. Also, in every winCE device I encountered I had no problem with running the programs (how they ran is another issue, but they always ran), so I don't think you should have a problem.
To be sure, you can ask your local NI office to build a small demo executable for you or you can ask someone here (I don't have access to a PC with the PDA module installed at the moment).
___________________
Try to take over the world!
(3,107 Views)
