Running LabVIEW applications on Windows Terminal Server
I have built a client application in LabVIEW that one of our users want to run on a Windows 2000 Terminal Server...the question is; how does Windows Terminal Server handle the different sessions; does is launch multiple copies of the application and if so how about support files? In my case the client application has a configuration and a temp file in it's directory...if multiple users use the application on the terminal server; does it or can it be set up to make one copy of the app directory for each session? If not - is there a way / what is the best way to get separate configurations and temp files for each session?
Message 1 of 1
(2,744 Views)
