Running Histogram
"If you run with executiom highlighting on (the light bulb on the diagram toolbar), you can see what the program is doing including the values on the wires at each time."
I did that, but since the tag for the robot position 11 changes abruptly, I can't time the execution right.
Is there another way of doing this?
Message 11 of 12
(673 Views)
Try a conditional probe, set to Pause if the condition is met. Break points can be useful also. You would need to put it inside the case structure so the loop doesnot pause on every iteration.
Lynn
Message 12 of 12
(657 Views)
