Running Datasocket in labview 2013 open labview runtime engine 7.0
Hello All,
I am trying to communicate with a COGNEX camera using Labview 2013. I am using Datasocket to read tags from cognex OPC server.
but when I open labview and run the code for the first time. An installer will automatically pop up trying to install labview runtime engine 7.0.
When i cancel the installation datasocket throws an error. Again if i run second time, datasocket works fine and communicate with cognex camera using OPC.
This problem comes everytime I open labview and run the datasocket. I cancel the installer. second time onwards when i run the code everything works fine.
This is actually annoying and i doubt how things will work when i make an executable.
Need help.
Is this due to datasocket version installed... how to resolve this.
(3,269 Views)
Just ran into the same problem with a brand new install of Labview 2019. However the run time installator will never stops and I have to stop Labview with ctrl-alt -delete. Someone has an idea of how to fix this problem?
(1,862 Views)
