Runing another idea inside a while loop
I want a while loop to run inside another while loop, The second while loop should work indefinetely while go is pressed, if go is unpressed it stops but if go is pressed again it runs again...
What am I doing wrong?
Message 1 of 17
(7,345 Views)
Looking at the code nothing looks 'wrong'. You've got one while loop running inside another exactly as you've described. Can you describe what you expect to happen?
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
Message 2 of 17
(7,329 Views)
I think, you would disable the code inside of second while loop if do == false. But it is a "post testing" (do) while loop, so your code will be executed firstly, after LV checks your condition. So you have to wrap into a case structure your while loop (pre testing), and your while loop will be executed only if do == true.
Balint
Message 3 of 17
(7,317 Views)
I want the while loop with thw button GO to work when the GO button is green, and that it can be turn on and off again without restarting the whole program
The idea is not hard, I just don't know how to do it
Message 4 of 17
(7,301 Views)
It is all about my "Go" button....
Message 5 of 17
(7,280 Views)
I don't see "GO" button, only "DO".
Message 6 of 17
(7,275 Views)
Yes that one
Message 7 of 17
(7,273 Views)
Accepted by topic author LP_C
Instead of a while loop inside of another loop, just use a case structure.  Embedded loops are typically a poor solution.
Message 8 of 17
(7,260 Views)
What is the significance to adding the 3E-14 to the loop counter?  After the first iteration of the outer loop, you will essentially be adding 0 to the loop count as the DBL precision variable will lose that resolution.  Are you expecting that?
Loop 0: Sum = 3E-14
Loop 1: Sum = 1
Loop 2: Sum = 2
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 9 of 17
(7,232 Views)
Loop 0: Sum = 3E-14
Loop 1: Sum = 1
Loop 2: Sum = 2
Maybe it is an attempt at mitigating some floating point precision issues?
Bill
CLD
(Mid-Level minion.)
Message 10 of 17
(7,224 Views)
