Run Vi from the front panel...
I'm trying to run a vi, but not from a run botton, and not even by the execution properties. I'd like the vi to run when i turn on same logic botton on the front panel. Is it possible? Thaks, sorry for my bad inglish. Obrigado.
(2,558 Views)
It is possbile to selectively run a vi using the VI server. I guess in your case you will still need to run a main to control the logic button. Check here for more information.
(2,558 Views)
