Run VI with I/O SERVER on another PC
Hello! I have created a VI for monitoring the inputs and outputs of a PLC, I use I/O SERVER from Labview and OPC server from MITSUBISHI, on the computer on which I created the program works without problems but when I try to run on another PC to which I installed the LABVIEW RUN TIME ENGINE and the OPC SERVER OF EMITSUBISHI does not work, it only runs the VI but it doesn't connect to the OPC, what programs do I need to install for it to connect correctly?, thank you
(730 Views)
Usually if something "doesn't connect", then you should have error code, which will tell you why it "doesn't connect". If you using "I/O SERVER from Labview", then it seems to be that you're using DSC, isn't? If so, then at least DSC Run-Time may also be needed as well.
Please show piece of the code how you connecting to your OPC server.
(682 Views)
