Run-Time application does not load correctly
If I build the App in LV6 and install it works. When I build the App in LV7, the app will not load correctly; ie. it takes about 5 minutes to load. This only applies to Win2000 - my XP machine loads the GUI fine.
(2,710 Views)
Hi:
Can you supply the app and the build file? I am in front of a WIN2K machine and I'll try to build it in LV7.0 and check it out.
Robert
(2,710 Views)
LabVIEW now uses the Microsoft installer. It's possible that you need to upgrade the version that's on the Win2K box. I think the latest service packs from Microsoft include it.
(2,710 Views)
