09-24-2008 10:44 PM
I'm new user for LabVIEW. Use the version of LabVIEW is 8.6
One problem describe as below:
Can Run-Time Menu and Event Structure exist simultaneously?
Without Event Structure, Run-Time Menu works well, but Run-Time Menu works abnormally.after adding Event Structure,
How do I modify the problem?
Thank you for your help.
Attached is the program.
09-26-2008 01:06 AM
Hi kchuang,
You might receive more help if you save your code for version 8.5 (some people haven't purchased 8.6 yet!
On your Main.VI, do File\"Save For Previous Version"
Cheers!
09-29-2008 10:54 PM
http://forums.ni.com/ni/board/message?board.id=5170&thread.id=2035
09-30-2008 07:09 PM
Thanks for your reply.
This issue has been solved.
KC
