Run-Time Menu and Event Structure~~HELP~~
Hi, brothers,
I'm new user for LabVIEW. Use the version of LabVIEW is 8.6
One problem describe as below:
Can Run-Time Menu and Event Structure exist simultaneously?
Without Event Structure, Run-Time Menu works well, but Run-Time Menu works abnormally.after adding Event Structure,
How do I modify the problem?
Thank you for your help.
Attached is the program.
(3,268 Views)
"Can Run-Time Menu and Event Structure exist simultaneously?"
Yes there is no problem.
Can you back save-it in 8.5 ?
(3,256 Views)
Yes they can coexist, but not how you did it.
Every iteration of the while loop you wait for an event in the event structure, and you look if the user has selected anything from the menu.
To get this working you should add an event for <this VI>\Menu Selection (User):
Ton
PS you should add a stop button, the only way you can stop the VI is hitting the 'emergency stop' button, with hardware connected (like you have) this is not the adviced routine
Message Edited by TonP on 09-26-2008 07:34 AM
My LabVIEW Ideas
(3,252 Views)
Thank you for your both reply.
Following Ton's method, it works well. Thanks.
In this project, it has no any I/O of hardware, only commucates with PC via Serial Port.
So, I don't add stop button to stop VI. end user can stop VI via "Exit item" of Run-time menu.
Another question:
What's the function of timeout for event structure? How to use it? How to set the time of timeout?
KC
(3,238 Views)
I have understood the mean of timeout for event structure.
Thanks.
(3,229 Views)
