Run Time Control Value Change for Debugging
LabVIEW can come with the feature where we can change control values on run time for more effective debugging and quick solution.
Here my idea to implement this feature can open opportunity to cange control value of a code running in loop and we can check control value change effect same time. No need to run code again and agin with different inputs.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(4,420 Views)
I am sorry, I don't understand what you mean. Are you proposing an Idea or sharing your thoughts? Can you please explain little more detailed?
(4,414 Views)
Please list to the idea exchange. I'm certain this has been suggested before so do a search and kudo the idea.
(4,401 Views)
Hi Himanshu,
is this the same like placing a control in a loop and changing it's value in the FP while using (step-by-step) debugging?
Something possible since "ever"?
Or do I get this wrong?
(4,380 Views)
Hi Himanshu
It is possible to change the control value at run time, if the control is placed inside the loop but not if the control is outside the loop.
As, LabVIEW follows dataflow model for running VIs, every node on the block diagram executes when it receives the required input and it executes only once and passes the output to the subsequent node in the path. A loop is also a node, it accepts the input and executes the code inside it. A code running inside a loop does not accept a new input from a control outside the loop when the loop is running. But if the control is placed inside the loop the code accepts a new input, thus enabling you to change the control value at run time.
If you have any more queries, feel free to ask.
Rohit Joshi
(4,351 Views)
I agree with Gerd. Your "idea" sounds like a good description of how LV already works -- and has since 1986. In fact in the Core 1 class there is a discussion of exactly what you are wanting. This is how dataflow works.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,335 Views)
