Run DLL in C++ from Labview
 You call delete[] on arrays that are parameters so your DLL _does_ modify parameters!
See snip below:
char PSIM[250];
_declspec(dllexport) int32_t dllbeta1(..., char cheminpsim[], ...)
  strcpy(PSIM,cheminpsim);
  delete [] cheminpsim;
Since LabVIEW doesn't allocate "char cheminpsim[]" via plain operator new[]
you _mustn't_ call delete[] on it!!!
And if you don't use your variables in other functions make the variables local.
Use global variables only if you have to.
It isn't a problem with LabVIEW here, any caller in C++ which doesn't use new[]
and calls your function will also fail in the very same manner.
Message Edited by candidus on 07-02-2009 08:59 AM
Message 11 of 12
(949 Views)
nobody for my F**k C++ code ?.... lol
It's maybe in my way to create DLL ...
thanks
Message 12 of 12
(927 Views)
