Route RTSI to PFI without counter
I have to connect my 6711 output card with the 6111 card that I'm using for the input through the RTSI bus. I can route the output UPDATE signal to the RTSI bus, but now I would like to pick it up in the 6111 card and route it to PFI5. I have seen the examples, but the problem is that I am using both counters in the 6111 card, so does anybody knows how could I redirect the signal from the RTSI bus to PFI without using a counter?
Thank you very much!
(2,792 Views)
Hello;
I'm not quite sure you are mentioning the counter to do a route operation, but, anyway, if your problem is only to route a signal from a RTSI line to PFI5, you can do that by using the Route Signal.vi, if you are using Labview, and the Select_Signal function, if you are doing NI-DAQ function calls.
Hope this helps.
Filipe
(2,792 Views)
