Round GUI
I was just wondering.  Does anyone know if there is some way to make a round Front Panel (or any shape other than rectangle)?  I wanted to make a GUI that was a shape other than rectangle, like Sonique.  Is this even possible in LabVIEW?
Jo-Jo
Message 1 of 9
(8,346 Views)
If you're on a Windows machine you can use the Windows API to do it. See attached for a simple example.
Message 2 of 9
(8,339 Views)
That's great, thanks a lot.  I apparently have a lot of investigation to do in regards to this.  I should be able to create some really cool GUIs with this.
Jo-Jo
Message 3 of 9
(8,331 Views)
With the proper playing around, you can create some nice stuff.
___________________
Try to take over the world!
Message 5 of 9
(8,293 Views)
Hi all,
   I want to create a hole in my GUI, and the discussion above helps me to reach near to my goal, but unfortunatly, i cannot make this running, can any one see am i calling the DLL in a right Manner.
Thanks In advance.
Regards
Harry
Message 6 of 9
(6,899 Views)
Hello all,
Done wrong names Used, get my problem
Harry
Message 7 of 9
(6,879 Views)
It's also possible (and simpler) to do this by making a specific color in the window completely transparent, which causes it to allow click-throughs.
You can see an example of how to do this here, although that was just quick and dirty code, so it needs some cleaning up. I don't even remember if the color which should be transparent is set up as an input there - http://forums.ni.com/t5/LabVIEW/Darren-s-Weekly-Nugget-04-17-2006/m-p/352929?view=by_date_ascending#...
___________________
Message 8 of 9
(6,858 Views)
My original desire to make a funny shaped window ended up evolving into a white paper (with example code), which you can view and download here:
https://decibel.ni.com/content/docs/DOC-9775
The example allows the user to select a black and white bitmap, which then clips the window to match the bitmap.
It should contain everything you need.
Message 9 of 9
(6,803 Views)
