Rotate 1D Array continuously
Hello
I am generating Sine Wave and sampling it at 12 samples/ Cycle and storing it in the array. I want to rotate this array continuously one sample at a   time. Suppose my array is [20 10 5 3 1],  I want this array as [1 20 10 5 3] (the last element become the first element)next time I want this array as [3 1 20 10 5 ].
Any Suggestions.
Sugandh
(6,286 Views)
You can use the 'Rotate 1D Array' VI in the Array palette.
Smiley Happy
(6,279 Views)
By Using 'Rotate1D Array' Array rotated one time only. I want to rotate 12 times. Or continuously.
Any suggestions
(6,272 Views)
Accepted by topic author Sugandh
(6,265 Views)
Sorry, I didn't check out your VI before suggesting the Rotate 1D vi.
The above code should rotate the array once per loop.
(6,261 Views)
You can connect the Waveform Graph to the output of the Rotate VI to view the sine wave changing phase. Smiley Wink
(6,259 Views)
It would be more universal if you would rotate based on the array size. This way you don't need to change constants and cases whenever the requirements change.
(Insert a "Negate" on the blue wire before the "rotate array" node to rotate the other direction)
Of course the "simulate" should be before the loop because the output is constant.
(6,215 Views)
