10-21-2008 10:18 AM
Hi Folks,
I'd like to roll back my 8.6 installation to 8.5.1. 8.6 no longer supports my Fieldpoint hardware. I wanted to upgrade mainly for some of the added usability features, such as multi-item properties, etc. Yes I could keep 8.6 but I like to keep installations and dependancies tidy and untangled.
So what is the cleanest way of uninstalling 8.6? I uninstalled *just* LabVIEW 8.6 from Add/Remove, and I had hoped that it would take along any associated packages. However now I'm left with a loooong list of software addons and I'm unsure which versions came with 8.6 (and which packages I simply had two versions installed prior).
Is 8.6 considered a major build? Is this why it left the 8.5.1 in-tact? Generally speaking I usually uninstall *any* software package before upgrading, but the install is time-consuming enough.
Anyway, thanks for any suggestions.
Best Regards,
Jamie
10-22-2008 02:17 AM
Is this correct - LV 8.6 no longer supports Fieldpoint??
I tend not to uninstall old versions but run them side-by-side with the new ones. It is then easier to work on a project that you want to keep at a particular LV version.
10-22-2008 06:32 AM - edited 10-22-2008 06:33 AM
No no, 8.6 discontinues support for cFP-20xx devices.
Is this really how you veterans run your installations? I have a hard enough time keeping track of all the addons + versions for distribution (self-installer) builds, etc.
No really, how do you keep this all straight and maintain sanity?? ![]()
Jamie
10-22-2008 08:07 AM
