Ring options display small
Hello, on my computer a while ago the display options for rings started appearing unreadably small (see below). It looks this way for small or large rings, on the front panel or back panel. Can anyone suggest a way to revert the text to normal size?
I am running Labview 2018 64-bit on Windows 10 Pro.
Thank you!
(2,410 Views)
Accepted by topic author zlasner
Are you using a high-resolution display (such as 4K)?  I've seen other threads mentioning Windows 10 scaling working oddly with LabVIEW on a scaled monitor.
Maybe try some of the stuff here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000004AZ9SAM&l=en-US
(2,393 Views)
Yes, this fixed it--in particular, changing the Compatibility setting to "Override high DPI scaling behavior" and restarting Labview. Thank you!
(2,336 Views)
