Ring formats
I'm using a ring, with 20pt font writing inside it.
But, the height of the ring is a lot higher than necessary, due to
formatting for looks.
However, the writing inside the ring, is always aligned to the top
Is there anyway to format the ring, such that the vertical alignment would
be centered?
(In case anyone has seen my last post's, and wondering if I'm an idiot....
I've only just started using LabView, with my new company, about two months
ago, and I'm still learning!)
thank you for any help you can give
Slade Squire
Programmer
Rectifier Technologies Pacific
0411 201 209
(3,001 Views)
Seems a bit complicated to have results, but you can customize your ring by editing the control, and place things where you want, at least is the only way (except using one or two returns before the string) i found in LV 5.0
Hope this helps
(3,001 Views)
Well... you can always resize the ring using the "Position/Size/Select" pointer.
You can see all the pointers available by selecting "Show Tool Palette" in the Window menu. Also, you can cycle all the pointers using the Tab button.
Regards;
EJV
www.vartortech.com
(3,001 Views)
