Ring Control default
[LV2015]
During run time, I am populating a ring control with the Strings[] property.  After the control is populated, the corresponding display defaults to the first item.  Is there a property node that I can set that will allow the control display to default to a non-zero position in the ring control?  I.E., instead of the control initially showing the 0-position (first item in the ring list), can I tell it to default to the nth-position?
GUJ
(3,096 Views)
Accepted by topic author GiantUncleJohn
You can set the "Value" property or write a value to the terminal of the ring control.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,093 Views)
