Ring Control Default Value
I have  a ring control which is having  a default value of <10200>.
I cannot replace this with a new ring control as i am using a lot of its property nodes in different cases.
How can I remove the default value..?
I have attached the control for reference.
(4,780 Views)
Accepted by topic author Flamboyant
You cannot remove a default value. You can only set a new, different default value.
Norbert
Norbert
Expert: Geometry
(4,779 Views)
How to set new different default value? Help me. Thanks.
(4,319 Views)
Enter a new value.  Right click  Data Operations >> Make Current Value Default.
(4,300 Views)
(4,282 Views)
