Rigid Body Position and Orientation Control via Simulator Display
Hi all;
I want to simulate a robot manipulator an LabVIEW Robotics 2013 Module.
I have watched a video on YouTube, and get some question marks.
The link is here
In this VI, the desired position and orientation definitions of end-effector
is obtained via Simulator Display Window
First;
I want to know how can I control position and orientation of a rigid body via Simulator Display Window with a mouse?
Thank you for your attention
(3,909 Views)
Are you trying to modify the property of position and orientation, or would you like to change the position/orientation based on an applied torque or force?
Nathan Murphy
NI C Series Modules Product Manager with an expired CLA
(3,879 Views)
Mr. Nathan;
In fact, I am trying to set position and orientation of the End-Effector with controlling a 3D axis.
I want to add a 3D axis in Simulator display, and change its position and also orientation with my mouse.
After that, my inverse kinematics algorithm will give the angle values for obtaining
the posture of End-Effector which I have defined with my mouse on Simulator Display window.
How can I add controllable 3D axis on Simulator Display Window?
How can I change its position and orientation with my mouse?
Please share an example VI with me
Thank you
(3,873 Views)
Accepted by topic author dncr
I've been asking around and it seems like our team in Shanghai may have the code that was used in the video. I'll let you know what comes up in the next couple days, we should have a community example in the works.
Nathan Murphy
(3,849 Views)
Thank you very much Mr. Nathan.
I will be waiting for your example VI.
(3,844 Views)
