Reversing an array for graphing
Hi everyone,
 I am trying to reverse a data array for a chart, however when the reversing array function is used the data seems to be reversed only half way.  I'm confused on why this is happening. Thanks for any help.
(3,022 Views)
The functions does reverse the entire array. Attach your VI with data so that it can be looked at.
(3,016 Views)
Sorry bout that,   CH 21 should be the one reading the 74.00 however I can't get it to that position
Thanks for any help
(3,006 Views)
Accepted by topic author nem
You'll need to explain what you want this VI to do. When run with the defaults, there is only a single element in the array.
Whatever you are doing, I'm sure the program is much too complicated.
(2,996 Views)
