Reverse Look-Up Table
In the IMAQ Reference Manual talks about predefinided look-up tables as
Equalize, Reverse, Square-Root and so on.
However I can't find the Reverse look-up table anywhere.
Does anyone know if it exists?
Thanks to all.
Miguel.
(3,416 Views)
Try the inverse LUT. It just gives you a negative image.
What version of IMAQ are you using? I know NI changed some things going to
IMAQ 2.2. In IMAQ 2.2 you can set a property node on IMAQ CREATE for
specifying the lookup table. I am using the 1411 IMAQ card which is a
little bit different from the 1408 IMAQ card.
Robert
Miguel wrote in message <37DFF6DE.77D47380@recol.es>...
>Hi,
>Thanks to all.
>Miguel.
(3,416 Views)
