Reuse Class
Hopefully a simple question.
I have a class hierarchy that I want to reuse.  How do I copy the class hierarchy to a new project?
Dan Shangraw, P.E.
(3,637 Views)
Questions about reuse may be simple, but the answers are not.
Paths in LV are relative, so the naive answer is that you simply copy all the files and folders in the same structure. If you copied everything correctly, this new copy works in exactly the same way as the original.
If you actually want to have a single copy shared between multiple projects, you would usually want to have it installed in a shared location. People often prefer this to be in a logical path, like vi.lib, because then it allows you to have multiple copies of the same code for different LV versions. Many people prefer having the source for the reuse component as a separate project and use something like VIPM to deploy the release reuse component to vi.lib.
Anyway, that's the 60,000 feet review of the topic.
___________________
Try to take over the world!
(3,580 Views)
Thank you for your reply.
Dan Shangraw, P.E.
(3,560 Views)
