Returning from LabVIEW EXE
How can I return a value from a LabVIEW EXE. I tried calling a LabVIEW EXE from another program but its always returing 0 upon exiting. How can I make the LabVIEW EXE return what I want to the calling program.
(2,811 Views)
Take a look at this KnowledgeBase which discusses passing data from the command line.
Building and Running LabVIEW Applications That Use Command-Line Arguments
If you are going to be using this exe as a function you may want to build it into a dll.
(2,811 Views)
