Retrieving Weather Information.
Hi everyone,
I tried searching for my enquiry but the results didnt seem to be accurate enough for me.
What I am trying to look at doing is retrieving the current tempreture from a website, say BBC weather, in LabVIEW. Even if I could just get information for one set place it would be enough, as I could work on multiple locations later if I had time.
Any tips or simple examples would be greatly appreciated.
(4,616 Views)
Try this: http://zone.ni.com/devzone/cda/epd/p/id/861  I did it a couple of years ago, and it worked great.
(4,601 Views)
I tried to run that example, it changed the title to Texas but no data came up :S
Basically I am trying to get the current weather from Heathrow Airport, London. I just need some basic info, any easy tips?
(4,548 Views)
Hello Intel,
If you click on this link you'll be taken to a Developer Zone article which will cover everything you will need to get going using s XML web service to achieve what you want in LabVIEW. Weather services are available from www.xmethods.net 🙂
https://www.ni.com/en/support/documentation/supplemental/08/labview-web-services-faq.html
Tom
NIUK
(4,514 Views)
