Retrieve the selected text from an ENUM, text ring or other control
Hi and thanks for reading.
I want to be able to select a line of text from a menu, and place that text
in a string variable. This seems simple but I haven't found the solution.
I don't want to have to wire a numeric output to a case statement, thus
having to type the text line twice
Stan
(2,874 Views)
First create a property node of the enum,text ring, etc. Select the "Strings[] property. Use this as the Input Array input of an Index Array function. Wire the control to the Index input of the Index Array. The ouput of Index Array will be the text of the control.
(2,874 Views)
Apart from the String[] property already suggested, for an enum you have the additional option to read the control and feed it to a "Format into String" node with %s format.
LabVIEW, C'est LabVIEW
(2,874 Views)
Please reply to mailto://stan.cehonski@lmco.com
"KB2WEN" wrote in message
news:aa90lh$36t$1@knight.vf.lmco.com...
text
> Stan
(2,874 Views)
