Retrieve data block from a complicated string
I ran a shell command on LabVIEW using System ExecVI and the result was returned as a string.
I want to retrieve a data block from the string. But the content in the string is very complicated.
Anybody has a good idea to find and retrieve the data block?
I have attached the returned string as a text file.
The data block has three columns with column labels as:
ORDINATE, ERROR, ABSCISSA
, but with additional graphical letters on the right of each row.
It is hard to explain and you may understand what I meant by taking a look at the attached file.
The data block I need starts from
"*+++++++ CHOSEN SOLUTION +++++++++++*"
and ends at
"*0LINEAR COEFFICIENTS*"
If you can suggest me the functions, I will try to create the code by myself.
Thank you in advance.
(1,609 Views)
Yes, it is not easy as your shell script creates graphs using character and data arrangement is quite special to make it readable but not easily parsable.
In terms of what functions to use, it would just be the string palette and array palette - but it depends on how clever you use those functions to make it scalable.
Good thing is that all columns are of fixed characters width. This is how I would approach this,
  1. Find the line containing " ORDINATE ERROR ABSCISSA" (line#815 in your example file)
  2. For each line after the header line
    • Check if it is of the format "3.046E-04 2.6D-04 5.00E-05" (use the appropriate scan from string format)
    • Scan into three values - corresponding to ordinate error and abscissa
    • If the line does not contain data of the format, this means it is the end of data (look for scan from string error)
Santhosh
Soliton Technologies
(1,591 Views)
Accepted by topic author Xiang00
Couldn't resist solving this, here you go.
VI in LV2016 attached
Santhosh
(1,583 Views)
Thank you very much for the kind suggestion and vi.
It solved my problem.
(1,575 Views)
